Date/Time: Sat, 18 May 2024 04:37:18 +0000
spreadsheet: how to plot only current value
View Count: 2654
[2015-09-24 16:05:36] |
jivetrader - Posts: 395 |
a formula i wrote tallies a value at every bar, kind of like a trailing stop loss. however, i would like to display it only for the current bar, not for every historical bar. how can i hide it on previous bars (by modifying the formula or some other means) ? thanks in advance.
[2015-09-24 18:20:01] |
One way is to update Sierra Chart to the latest prerelease and use this new Study Subgraph Draw Style: Line at Last Bar to Edge.
[2015-09-24 20:17:15] |
Sawtooth - Posts: 4000 |
To do it with a spreadsheet formula, try this: =IF(ROW()=3,YourConditions,0) |
[2015-09-25 01:32:43] |
tom, this is the kind of solution i was looking for, however the formula relies on previous values in the column being present (starting from row 4), and your formula won't process rows other than row 3. so i guess i will have to 1. use a helper column or 2. try to hide them instead, using SC solution above. thanks
[2015-09-25 03:24:00] |
Yes, in that case you'd need to use another 'helper' Formula Column.
