Date/Time: Sat, 18 May 2024 04:37:34 +0000
Yesterdays daily high on todays 15min chart
View Count: 758
[2015-09-24 14:23:52] |
User170575 - Posts: 221 |
Hi, Is there a way to put a line on a 15min chart that represents yesterdays daily high or low? Many thanks, Cy |
[2015-09-24 16:55:52] |
Yes. This can be used by using the Daily OHLC study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 The Open, Low, Close lines can be hidden by setting the Draw Style to them to "Ignore" in the Subgraph Settings for the study. Here are instructions to add a study to a chart: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
