Date/Time: Sat, 18 May 2024 13:22:33 +0000
Missing Dependency File
View Count: 784
[2015-09-24 14:18:10] |
Zosimus - Posts: 345 |
I built a custom study with Visual C++. The study works smoothly on my Sierra but when I share it with others they get a "Missing Dependency File" error. When I compile the study with the SC built in compiler instead of compiling with Visual C++ they do not get this error. Any idea? |
[2015-09-24 17:55:16] |
It is necessary to statically link with the C++ runtime libraries. This is explained at step 11 in this section here: https://www.sierrachart.com/index.php?page=doc/doc_VCExpress.php#ConfigureProject Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-24 21:57:08] |
yes this solved the "Missing Dependency File" problem but now their SC crashes when they load the studies. I will first check that all my other VS properties are correct and will let you know.
[2015-09-25 12:04:58] |
solved. great support, thanks.
[2015-09-25 18:07:11] |
This is good.
