Date/Time: Sat, 18 May 2024 08:23:45 +0000
Scaling in strategy
View Count: 704
[2015-09-24 07:34:10] |
User832215 - Posts: 27 |
How do you scale in with your trades? for example: Trade1 I enter at 1900 on the ES and then for Trade 2 I want to enter on a buy-limit order at 1905. I also want to manage the trades separetely, meaning that I will have different stoplosses and targets for each trade. |
[2015-09-24 18:34:02] |
This is very straightforward. You will enter each of these as separate orders. In each case you will need to use Attached Orders which are documented here: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
