Date/Time: Sat, 18 May 2024 13:22:58 +0000
Stop-Limit offset resets itself to 0 value
View Count: 729
[2015-09-24 06:47:08] |
User505707 - Posts: 14 |
Hi, I use chart DOM and 'Simple bracket' for entering my orders on Interactive brokers. I use for my primary order Stop-Limit with limit offset of 4 ticks (on chart DOM). I have saved all, and when I close and open Sierra, that limit offset is then reset to 0. Didn't had any other issues with orders. Please investigate, Thanks Date Time Of Last Edit: 2015-09-24 06:59:20
[2015-09-24 08:03:14] |
We will be checking into this right away.
[2015-09-24 18:14:19] |
This is now solved. Update to the latest revision of the prerelease by using Help >> Download Prerelease.
