Date/Time: Sat, 18 May 2024 06:22:38 +0000
Auto moving a stop with time
View Count: 1119
[2015-09-23 22:51:03] |
Infinite - Posts: 134 |
I use a triggered stop that moves my stop to breakeven +4 after 5 ticks. I use a STOP instead of a target, so if there is momentum on that trade the STOP gets moved to breakeven +4 and have my TARGET is set at 3-4 points. I want it to work exactly like it does with an addition to having a delay timer of 5 seconds before it moves my stop to BE +4, instead of an instant move to BE+4.
[2015-09-24 04:47:48] |
There is no built-in support for this. It would require custom programming using ACSIL: http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
