Date/Time: Tue, 07 May 2024 11:26:51 +0000
Suggestion to Engineering
View Count: 1530
[2013-06-17 03:21:12] |
User59821 - Posts: 6 |
Hi, i wonder if it would be possible to be able to duplicate an added study-by just doubleclick on that study .For example-if you wanted 2 identical moving averages- but in different regions-you would just doubleclick on that MA that you added in your list(with your settings) and just change the number of the region without having to add all the settings-each time you want to add that MA in the list.If you think this may be useful-it would be a nice feature for a future version,Thanks |
[2013-06-17 08:46:42] |
TastyRisk - Posts: 119 |
+1 - It'd be great if we could select multiple studies, copy them, and append the copies to the end of the list. I think Engineering is busy on other things, you know?, User59821. |
[2013-06-18 01:07:26] |
M5amhan - Posts: 468 |
have either of you tried using the "save these settings as the default" option? clicking on the chart selecting a study could prove to be very annoying (as ninjatrader does) for those of us always clicking and moving the charts around while managing trades |
[2013-06-18 04:18:37] |
We will see about adding a Copy button for a selected study, to the Study Settings window. Post #3 also has good information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
