Date/Time: Sun, 19 May 2024 12:53:23 +0000
Automatically screenshot in Sierra Chart
View Count: 1416
[2015-09-20 09:04:41] |
User95130 - Posts: 9 |
Hi, I would like to ask you if it is possible to set the sierra to automatically creating the screenshot of the screen at the moment of the entry time. And automaticallly save it e.g. to c: \ SierraChart \ Images \ ?? Thank you for your help. Date Time Of Last Edit: 2015-09-20 09:05:09
[2015-09-20 09:19:55] |
This is supported only through ACSIL. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html You will need to use sc.SaveChartImageToFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-18 13:49:18] |
Cavalry3162 - Posts: 523 |
has someone coded that already? it would be awesome if this could be shared. thanks a lot, Andreas |
