Date/Time: Wed, 15 May 2024 10:55:56 +0000
Problem with a data connection
View Count: 688
[2015-09-18 20:21:58] |
AC90075 - Posts: 1 |
Hi. I have a new notebook with Windows 10. I have installed Sierra Chart and was charged I usernames and passwords for Sierra Chart and for a data feed provider - Ritmic. The software will not connect. I added in the Annex photo. Can you help with that? Sincerely Peter Zetocha |
2015-09-18_22-07-47.png / V - Attached On 2015-09-18 20:13:44 UTC - Size: 134.86 KB - 275 views 2015-09-18_16-49-23.png / V - Attached On 2015-09-18 20:14:01 UTC - Size: 132.89 KB - 264 views 2015-09-18_16-49-48.png / V - Attached On 2015-09-18 20:14:06 UTC - Size: 132.48 KB - 280 views 2015-09-18_16-49-11.png / V - Attached On 2015-09-18 20:14:11 UTC - Size: 42.4 KB - 296 views |
[2015-09-18 22:31:12] |
We see you are having trouble connecting to Rithmic which is a very common problem. Most likely you are getting a "permission denied" error. Refer to step 17 here: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
