Date/Time: Wed, 15 May 2024 04:02:22 +0000
Chart drawing tools - how to isolate text in a extended rectangle box?
View Count: 970
[2015-09-18 19:36:18] |
Marc P - Posts: 29 |
I am having some trouble isolating the drawing text from the extended rectangle that the text is in on my chart. When I try to move the text, the software only recognizes the extended rectangle. Is there some way I can isolate the text within the extended rectangle? Many thanks, Marc |
[2015-09-18 22:15:59] |
No, if you set text on an Extending Rectangle chart drawing, it is part of the chart drawing and cannot be moved separately.
