Date/Time: Sun, 19 May 2024 05:43:50 +0000
Relative Volume study showing different results on 5min and 1min charts
View Count: 1181
[2015-09-18 13:44:22] |
User25850 - Posts: 13 |
Hi, As the title says, when applying the Relative Volume study to the 5min and 1min charts, I'm getting different readings on the Cumulative Volume Ratio. Any idea why this is happening? Thanks |
[2015-09-19 10:04:09] |
We are looking into this and will write up some information with what we find.
[2015-09-29 14:47:31] |
Hi, any updates regarding this? Thanks |
[2015-09-30 03:22:28] |
We apologize for the delay. We are checking on this.
[2015-09-30 04:58:51] |
We made a small change which should help with this in part. Update to the latest prerelease with Help >> Download Prerelease.
[2015-09-30 12:36:58] |
Thanks, but the discrepancy is even bigger now. Over a 5 day lookback period, the ES 5min chart is showing 121% for 9/29, while the 1min is showing 98.9% The 5min data seems about right but not sure which one to trust now. I'm on version 1301 Thanks |
[2015-09-30 18:03:27] |
We will check again, but there is going to be a difference. This is normal. We will write up some documentation to explain why.
[2015-09-30 18:12:23] |
I also noticed a new bug with the new update, after a while, the ratio tends to drift lower down towards 0. I reload the chart and it recalculates correctly. This wasn't an issue with version 1300. Thanks for looking into this. |
[2015-09-30 18:26:45] |
OK we are going to check on this.
[2015-10-01 01:14:32] |
Trader Ra - Posts: 87 |
i use this study daily so hope this gets resolved soon. im on 1300 now so will not be updating my version until this is sorted. :)
