Date/Time: Thu, 16 May 2024 15:13:55 +0000
Ask Bid Volume at Price
View Count: 822
[2015-09-17 13:56:01] |
User115786 - Posts: 6 |
Hi, I am using a range bar chart with the Numbers Bars study and a Spreadsheet study, with the Output Volume At Price Data set to Yes. Is it possible to output the Ask Volume and Bid Volume at price as well? If this is not possible, how can I access the Ask and Bid Volume data at several price levels for each bar? Many thanks, Trev |
[2015-09-17 18:36:21] |
You can only do this using ACSIL: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scVolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
