Date/Time: Thu, 16 May 2024 04:42:35 +0000
displayed alert limit
View Count: 723
[2015-09-17 03:49:16] |
aydex - Posts: 110 |
http://www.sierrachart.com/image.php?l=1442461704703.png Hi, Please tell me what (besides not meeting conditions) might be preventing seeing alerts prior to 9-8 thanks |
[2015-09-17 05:29:40] |
Sawtooth - Posts: 3997 |
If you are using the Color Bar Based On Alert Condition study to paint the arrows, the default Number of Bars to Calculate is 2000. If you are using a spreadsheet study to paint the arrows, the default Number of Rows (bars) setting is 1000. Bars prior to those settings will not show any historical arrows. To see more historical arrows, you could increase the lookback with a change of the settings, or you could scroll the chart into the past and do a Replay Chart, then press Pause. |
[2015-09-18 05:04:24] |
You are using the Spreadsheet System/Alert study. You need to increase the Number of Rows input: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#NumberofRows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
