Date/Time: Thu, 16 May 2024 16:03:54 +0000
Compact Tool Value Window
View Count: 847
[2015-09-16 23:34:01] |
User35326 - Posts: 57 |
SC: I just updated to version 1296 and now the font is so small in my compact tool values window that I can't see the prices. How can I change that back to the font size I had it before you changed it? Also, SC, I am a trader, I am not a chart window font changer, please try to not change my existing setup when you do an update. My time is as valuable as your time is. Thanks in advance. Date Time Of Last Edit: 2015-09-16 23:34:59
[2015-09-17 01:45:23] |
The font is controlled through Global Settings >> Graphics Settings. It is named Compact Tool Values Window. Here is the documentation for it: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html The font was supposed to keep its original setting, but the code that controlled that was not referencing the correct font. It was referencing one of the system fonts instead as if it was a new installation of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-17 01:58:05
