Date/Time: Sat, 18 May 2024 22:45:26 +0000
TRADING SYSTEM
View Count: 732
[2015-09-16 16:04:19] |
User82615 - Posts: 106 |
Hello I'm trying to develop a trading system that has the heiken ashi indicator in it. But I must be doing something wrong because it doesn't work when I put it in a chart. I'm sending the ACSIL code f this system to you, so if you are so nice to tell me what I'm doing wrong?. Thank you very much in advance |
Private File |
[2015-09-16 18:44:43] |
We do not provide programming help or debugging services. Refer to this section here for help: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#DebuggingTradingSystems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
