Date/Time: Sat, 18 May 2024 18:47:19 +0000
bars of the Ask/Bid Difference study appear misformatted
View Count: 780
[2015-09-16 15:50:28] |
User12089 - Posts: 350 |
Some of the bars of the Ask/Bid Difference study appear misformatted on 4 range charts, on 14 range charts the effect is absent - see screenshot attached
9-16-2015 4-40-57 PM.bmp - Attached On 2015-09-16 15:49:06 UTC - Size: 354.43 KB - 316 views |
[2015-09-16 18:07:20] |
Are you referring to the Ask/Bid Volume Difference Bars study? Make sure you have a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
