Date/Time: Sat, 18 May 2024 21:06:00 +0000
Alert conditions
View Count: 836
[2015-09-13 17:50:58] |
User94740 - Posts: 333 |
Hi, can anybody tell me what is wrong with this alert condition? thx! =H-(H-L*.15)>=C |
[2015-09-13 20:10:32] |
There is nothing wrong with the general format of that formula.
[2015-09-13 20:29:47] |
thx, but I wish it would give me an alert. Alert is enabled with a designated alert sound, but nothing.
[2015-09-16 16:32:44] |
I would also like to know, if it is possible to have two conditions on separate lines for an alert
[2015-09-16 18:35:31] |
To use 2 conditions use the OR or AND function in the Alert Condition formula. These are documented here: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetFunctions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-16 20:40:15] |
thx, but is there any possibility to use two lines or does everything have to be combined into one complete line?
[2015-09-16 20:44:01] |
It does need to be one complete formula.
