Date/Time: Sat, 18 May 2024 04:05:17 +0000
Is there a way to keep the same chart visable across all Chartbooks?
View Count: 706
[2015-09-13 17:15:03] |
User170575 - Posts: 221 |
Is there a way to keep the same chart visable across all Chartbooks? Many thanks, CJ |
[2015-09-13 17:18:24] |
Plz cancel that---"duplicate chart to chartbook" thanks |
[2015-09-13 22:07:29] |
There is a way to specifically do this and it is documented on this page here: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
