Date/Time: Sat, 18 May 2024 04:54:33 +0000
Login - Connection was closed before a response was recieved
View Count: 770
[2015-09-11 20:46:52] |
shullva - Posts: 4 |
In trying to fire up Sierra Chart I now get the following error after the login button is hit- HTTP Error: the Connection was closed before a response was received Any suggestions as to what to look at? |
[2015-09-11 21:45:34] |
Disregard the prior response. It did not apply in this case. This is the relevant documentation: https://www.sierrachart.com/index.php?page=doc/doc_HTTPCommunicationErrors.php Sounds like a firewall is blocking the connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
