Date/Time: Sat, 18 May 2024 06:49:09 +0000
Can you manually backtest by replaying a chart one bar at a time on daily timeframe?
View Count: 921
[2015-09-11 20:44:37] |
User418222 - Posts: 1 |
Hello, the reason I am interested in Sierra Charts is for manual backtesting on the daily. Basically I would like to go back to a certain date and see the chart up to that date. Then click and have one day revealed at a time so I can manually do entries and exits to backtest ideas. From what I could tell on the literature this is only available on intraday charts. Is there any way to do it with daily bars? Thank you! |
[2015-09-13 01:27:19] |
You can replay Daily bars by setting an Intraday chart to 1 Day per bar. Here is the documentation for that: https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#ReplayingHigherTimeframeCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
