Date/Time: Mon, 06 May 2024 08:47:35 +0000
Diagonal Lines / Multiple Time Frames
View Count: 910
[2015-09-11 13:53:20] |
User55519 - Posts: 37 |
Hello, I'm having a problem. If I have multiple charts open, each using a different time frame (let's say 60min, 30min, 10min, and 5min), if I draw a diagonal line on the 60 minute chart, it appears in the proper place on all the other charts. BUT if I check a 1min chart, the lines are completely in the wrong place. I'm using the Chart Setting option to copy drawings to the other charts from the first one. Basically, any time frames shorter than 5mins copy drawn lines in completely the wrong place (2min, 3min also). They are not slightly wrong, but really far off. Horizontal lines do not have this problem. I found a section in the help documentation that seems to address this, but I followed the couple of steps there and it didn't change anything. Any ideas on what I can do to fix this? |
[2015-09-11 17:04:36] |
This is the relevant information on this subject: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html#ChartDrawingsMisaligned There is not any more information we can provide about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
