Date/Time: Sat, 04 May 2024 04:30:18 +0000
How can I change the start time on a Daily chart
View Count: 754
[2015-09-10 20:46:00] |
User428971 - Posts: 26 |
Hello. I would like to change the start time on my daily charts to 6 pm eastern time. When I click on Chart, Chart Settings it is grayed out on the daily charts. I can see how to change the time of a chart smaller but not the daily's. Thank you.
[2015-09-10 20:51:29] |
infpz - Posts: 826 |
Hi. Make it an intraday chart that is 1440 minutes per bar.
[2015-09-11 05:27:49] |
This is not possible to change. However, you can use Intraday data as has been said. Refer to this page: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
