Date/Time: Mon, 29 Apr 2024 02:24:55 +0000
Manage Chart Drawings Window Needing Improvement
View Count: 806
[2015-09-10 06:45:43] |
Trader Ra - Posts: 87 |
The Manage Chart Drawings Window could do with an improvement to help manage drawings better like adding to it more filter options. Right now, we can only filter by drawing type. why not add more filters to the window like drawn date, text label, config name, price, etc. or instead of filters.. how about adding more description columns in the current list that identifies each drawing better with the identifiers i mentioned above... much like the standard windows explorer windows where you can sort all items by name, label, date modified etc. that would make the window infinitely more useful. right now, its difficult to quickly find a particular line if you have 10+ lines drawn as an example. those extra descriptors and filter options in the window would save a lot of time scanning between chart and window to work on them. is this difficult to implement? |
[2015-09-10 07:11:23] |
Yes, this functionality is difficult to add and we are not accepting new suggestions at this time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-10 07:12:08
[2015-09-10 07:13:55] |
If this is very important to, you would need to be willing to pay for the cost of this development. The cost would be about 50 USD per hour. Otherwise, there really is no chance of seeing anything like this for years. We are not going to take on any tasks which cannot be done within a few months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-10 07:24:20
