Date/Time: Sat, 04 May 2024 21:55:00 +0000
QUESTION: Overlaying windows
View Count: 679
[2015-09-09 18:36:53] |
User947911 - Posts: 12 |
Hello, currently, I was wondering if it is possible to have one chart inside another one, while they do not overlay when the bigger chart is clicked on. What I mean is, I got two charts, bigger one and another chart inside it. But I want the smaller chart to remain visible even though I click on the bigger chart. Now, when I click on the bigger chart, the smaller hides behind it. Thank you in advance. |
[2015-09-09 19:39:38] |
This is possible only with detached charts: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html A detached chart can be set to be Always on Top and that page explains how to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
