Date/Time: Thu, 02 May 2024 16:49:09 +0000
what happened to "Show Y Value and Time Boxes With Pointer Tool"
View Count: 793
[2015-09-09 17:12:48] |
User26971 - Posts: 7 |
This setting is missing under Global Settings >> Tool Settings >> Chart Values in version 1293 I need to see the price and time under my Pointer when I move it across the charts. Thanks. |
[2015-09-09 18:06:03] |
After a review of the Chart Values Tool, this option did not make sense and it did not work entirely as it was intended. You need to use the Tools >> Chart Values tool which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues To make it similar, you can set the following in Global Settings >> Tool Settings >> Chart Values: Uncheck "Show Crosshair" Check "Always On When Chart Values Tool Selected" If you do not want to see the Compact Tool Values Window then uncheck Window >>Show Compact Tool Values Window Please do not ask for the previous behavior back because it will not be added back. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
