Date/Time: Sun, 05 May 2024 00:29:09 +0000
Symbol Settings Window
View Count: 743
[2015-09-09 15:20:57] |
MKL17 - Posts: 35 |
Every time I attempt to open the symbol settings window the main windows page is frozen, almost as if the symbol settings page has popped up but it cant be seen. Thus, when I click on anything it gives me the sound you get when you have a pop-up open yet I cannot find the actual symbol settings page that I have opened. If I go to my charts that I have detached those work so I know the program is working and its just a case of the symbols setting page opening and possibly hiding or something of the sort. any ideas? Other pages open fine. Just as follow up, this applies only to the global symbols pop up not the individual symbols setting page.
Date Time Of Last Edit: 2015-09-09 15:26:49
[2015-09-09 18:30:08] |
This is an operating system level problem. When you notice this problem, press the Escape key to close the Symbol Settings window you cannot see. The solution is generally going to be to close programs on your system and/or restart your computer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-09 18:30:34
