Date/Time: Sun, 28 Apr 2024 13:58:42 +0000
chart shortcut menu
View Count: 732
[2015-09-09 15:09:01] |
Dennis B. - Posts: 263 |
Running ver.1282 on 3 instances of SC, no problem yesterday. All of a sudden on 1 instance of SC when I click on the shortcut menu and try for parallel lines I get the par. lines config box can do nothing with that, other tools same thing. The other 2 instances of SC are ok...so far.
[2015-09-09 17:58:45] |
What do you mean by "can do nothing with that". We are not understanding the problem.
[2015-09-09 18:05:37] |
All you get is a "config box" you do not get the tool you want, like rays, parallel rays, vertical lines etc....Like I said 2 instances ok, one got corrupted some how.
[2015-09-09 18:10:07] |
What is the exact name of the menu command you are selecting on the Chart Shortcut Menu? It is not possible for corruption like this to occur. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-09 18:51:40] |
Ok, reset everything and now ok,but something got messed up in that one instance of SC.
