Date/Time: Wed, 01 May 2024 20:07:04 +0000
Order Rate Action - exceeded error
View Count: 782
[2015-09-09 14:04:17] |
AP - Posts: 117 |
Any idea if I can change some setting in SC to accommodate higher order entry rate action?
[2015-09-09 17:32:51] |
This error comes from CQG. Please contact your broker to have them make the necessary adjustments that you require.
