Date/Time: Tue, 30 Apr 2024 12:49:57 +0000
Way to Delete All Chart Lines AFTER a Specified Date?
View Count: 911
[2015-09-08 23:27:16] |
ged - Posts: 233 |
It is easy to delete all lines from a chart, but is there a way to delete all lines after a specified date (leaving lines prior to that date in tact)?
[2015-09-09 01:23:22] |
This is not directly supported. However, you can see all of the Chart Drawings through Tools >> Manage Chart Drawings Window and can delete them from there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
