Date/Time: Tue, 30 Apr 2024 20:12:55 +0000
Stop orders in opposite directions
View Count: 1712
[2015-09-08 15:10:05] |
pkhst958 - Posts: 52 |
Hi I would like to initiate by (Buy Entry, Sell Entry) stop orders in opposite directions, one sell stop and one buy stop. I have triggered both by the same formulae, but only the buy order is transferred to ib. I have set j69=true. |
[2015-09-08 17:37:36] |
This should work. The reason why the order is being ignored is explained here: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#IgnoredSignals What is the reason the order is being ignored? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-09 05:04:46] |
Almost solved, I found this trade service log entry "SellEntry signal is ignored because working orders exist." The working order is buy stop. |
[2015-09-09 18:27:26] |
So in this case you need to set this to TRUE: https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php#AllowEntryWithWorkingOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
