Date/Time: Sun, 05 May 2024 22:50:03 +0000
[User Discussion] - CANNOT CONNECT
View Count: 1031
[2015-09-08 13:38:12] |
jivetrader - Posts: 387 |
Open E Cry FIX | Connecting to trading server prod.openecry.com. Port: 9400. | 2015-09-08 09:36:50 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-09-08 09:36:50 OEC FIX Trading socket (65) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-09-08 09:37:11 OEC FIX Trading socket (65) | Shutdown and closed. | 2015-09-08 09:37:11 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2015-09-08 09:37:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-08 09:37:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-08 09:37:11 OEC FIX Trading: DisconnectFIX called. | 2015-09-08 09:37:11 Disconnected from Open E Cry. | 2015-09-08 09:37:11 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-08 09:37:11 |
[2015-09-08 15:33:01] |
SOLVED this was a Bitdefender Total Security 2015 issue on Win7-64. adding an exception for Sierra to connect thru the firewall does NOT allow it to connect. the following procedure must also be done: http://forum.bitdefender.com/index.php?showtopic=35604&st=0&p=153821entry153821 |
