Date/Time: Sun, 28 Apr 2024 18:35:47 +0000
How to have the historical daily data just for current contract
View Count: 703
[2015-09-08 04:56:21] |
ejtrader - Posts: 688 |
SC Team - in General when I open an ES Daily Chart - it would have the data from prior contracts as well ( auto back-adjusted ). Is there any way to have data Just for the current Contract without any other back adjusted data from prior contracts for a historical chart? One of the options I can think of is to open an intraday Chart. However would like to avoid opening an intraday chart - but just daily chart. Any suggestions? Thanks Date Time Of Last Edit: 2015-09-08 04:57:17
[2015-09-08 05:17:01] |
We would think this would be obvious. You just need to not use the Continuous Futures Contract feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html So set it to None through Chart >> Chart Settings >> Advanced Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-08 06:03:08] |
Thanks. I actually had it set that way. As the first date for the Sep-15 contract going back to 2014-06-11 had an incorrect assumption that it is including data from prior contracts. All good. thanks. |
