Date/Time: Fri, 03 May 2024 20:16:47 +0000
all Financial Excel Functions
View Count: 1112
[2015-09-07 18:10:15] |
User572003 - Posts: 1 |
Hello, I decided to evaluate SierraChart because I hit his structure with spreadsheets inside, which enables a bidirectional data flow, from SierraChart to the spreadsheet and from the spreadsheet to SierraChart. However, considering the functions provided by the spreadsheet, I noticed that they are only part of those found in Excel. In fact, I expect to find all the functions of Excel! In particular, all those financial. So the question I ask to the technical support is this: how can I take advantage of the beautiful idea of ​​spreadsheets integrated without renounce to a part of the functions of Excel? For example if you wanted to calculate the yield to maturity of a bond with semi-annual coupons given the price (for example, the futures price), and redemption at maturity (typically 100) I can do this now with Excel easy,but with spreadsheets integrated in SierraChart, there isn't this function. So, the question is: The only solution is to jump integrated spreadsheets and pass the data to Excel, or is there a way to expand the functions of the spreadsheets in SierraChart integrated with those of Excel? Thanks for your attention Antonino |
[2015-09-07 19:31:14] |
Sierra Chart will not be adding the financial functions to the built-in Spreadsheets and we do not recommend using the feature to link Sierra Chart to Excel. We cannot provide any further help on this subject. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
