Date/Time: Mon, 29 Apr 2024 14:28:45 +0000
Highest High and Lowest Low based on Open/Close only, ignoring candle wicks
View Count: 967
[2015-09-07 14:11:49] |
User44052 - Posts: 34 |
Is there a way to get the sc.Highest and sc.Lowest functions to return values based only on the body of a candle over N bars. In other words, I want the highest high N bars ago to be based on only open/close prices, WITHOUT taking into account the High and Low. Any help is appreciated. |
[2015-09-08 02:03:54] |
Yes this is possible. You just need to pass through either the Open or Close arrays to the sc.Highest/Lowest functions. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseDataIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
