Date/Time: Tue, 07 May 2024 15:46:18 +0000
Easier way to get single volume profile along side a TPO chart?
View Count: 889
[2015-09-05 19:57:24] |
Todd Edwin King - Posts: 8 Invalid SC Account Name. |
Part of my current setup involves two charts with the TPO chart in front of a single VbP chart based on similar underlying data [see attached image]. This is the best way I've found to present the view I want - are there better ways? Problems with this setup: - I need a separate chartbook for each market, other wise disturbing the window positions becomes problematic. - Getting/keeping the vertical scales aligned is difficult. - I would like to have the peak/valley lines from the VbP study extended over the TPO chart. Thanks, |
TPO+VbP.png / V - Attached On 2015-09-05 19:55:26 UTC - Size: 51.18 KB - 385 views |
[2015-09-07 09:17:05] |
We do plan hopefully before the end of the year the capability to use a Volume by Price study on the TPO Profile chart which differs with the time period used by the TPO Profiles.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-07 19:36:43
[2015-09-07 14:32:54] |
That certainly would be ideal for my setup - the image I attached includes a (hidden) VbP on the TPO too. One thing that would help in the mean time is a chart link option to link vertical scaling. Thanks, |
