Date/Time: Sun, 28 Apr 2024 11:30:08 +0000
Data feed and charting efficiency
View Count: 830
[2015-09-04 12:14:29] |
User87197 - Posts: 65 |
Hi SC. As someone who uses the SC live data feed (and interactive brokers) - would it be more efficient CPU-wise to run two instances of SC: one instance of SC to receive the data feed and then a second instance of SC to chart the data? Many thanks, |
[2015-09-04 18:23:57] |
No. This would not make a difference. It might even use more CPU usage.
