Date/Time: Mon, 29 Apr 2024 19:30:39 +0000
Trade entry-exit lines
View Count: 1177
[2015-09-04 07:06:12] |
User76749 - Posts: 8 |
Hi, please could you help me with settings of Trading entry-exit line? If I do a trade with entry and exit in the same bar my line is somehow shifted (screen 1). I would like to have it direct, connected place of entry and exit (as on screen 2). Thank you! |
screen 1.png / V - Attached On 2015-09-04 07:05:33 UTC - Size: 1.4 MB - 345 views screen 2.png / V - Attached On 2015-09-04 07:05:49 UTC - Size: 1.26 MB - 335 views |
[2015-09-04 07:41:57] |
We will check on this. Also when posting an image of a chart, only follow the method described here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image And only post a single chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-21 15:01:51] |
Please see the screen. There are three trades. On the first and on the third trade are connecting lines between entry and exit shifted. Only on the second one is the connecting line right. What is the reason? Can you help me? Thanks. http://www.sierrachart.com/image.php?l=1448117706314.png |
[2015-11-22 02:45:31] |
Uncheck Global Settings >> Tool Settings >> When Mapping Chart Drawings to Bars, Use Nearest Match Instead of Containing Match. In the next release this option will not be used for the connecting lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-22 18:18:20] |
Thank you! Perfect.
