Date/Time: Sun, 05 May 2024 11:37:20 +0000
1291 - DOM display issue
View Count: 1050
[2015-09-04 06:19:56] |
normal guy - Posts: 16 |
Hello, Installed version 1291. As you can see on the attached picture, DOM displays the level with incorrect position. Thanks. |
ScreenClip.png / V - Attached On 2015-09-04 06:18:39 UTC - Size: 263.77 KB - 358 views |
[2015-09-04 06:44:46] |
We apologize for this. We are fixing this now. This was unexpected.
[2015-09-04 07:39:18] |
We have released version 1292 which solves the problem with the market depth display columns on the Chart/Trade DOM. Update Sierra Chart by following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-04 08:13:19] |
Thank you for the quick fix. It displays correctly now. |
[2015-09-06 03:28:09] |
JayShea - Posts: 92 |
I feel rather foolish, but I'm intrigued by the visuals in Foolish Guy's ChartDom etc. in his .png in #1 above. I can't seem to find how to change the background color of just the Buy-Sell ladder as well as have it change based on above-below the current price. Help, please. Thanks JD |
