Date/Time: Sat, 18 May 2024 11:36:44 +0000
scale range: constant range / scale range: constant range autocenter
View Count: 951
[2015-09-04 03:54:39] |
User144295 - Posts: 59 |
Hi Sierra Team, I would like to configure keyboard shortcut to switch between scale range: constant range and scale range: constant range autocenter Would you please help me to find this in menu so I can assign shortcuts for this? Thank you |
[2015-09-04 19:52:43] |
Keyboard shortcuts for these are not currently supported but they will be in the next release.
[2015-09-06 02:11:25] |
Thank you. Today I installed the latest release (1292 dated as Sept 5) but maybe I miss it somewhere. Would you please confirm if it is already in this 1292 version or it would be in the one after (1293)? Thank you. |
[2015-09-06 02:17:06] |
We have not yet released this. It will be in 1293. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-14 01:13:42] |
Hello Sierra team, I just tested this new functionality. I set shortcut for numbers bar chart ALT+F9 and ALT+F10 but chart does not change the scale. Would you please test on your end if it works? Thank you |
[2015-09-14 04:21:05] |
We do see the problem. We will be working on this in the next few days.
