Date/Time: Tue, 07 May 2024 15:03:10 +0000
highlighting the close
View Count: 965
[2015-09-03 15:45:03] |
User75949 - Posts: 108 |
I need to sign on a 24h chart (es a 5min candlestick) where the RTH (Regular Trading Hours) close is, for example for stock indexes at 15:00 CT Which indicator can I use to highlight the close with a point or a star o something else?? tks |
[2015-09-03 17:35:54] |
We recommend using the Time Line study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-04 10:58:54] |
Ok tks, but is it possible to put just a point into the last bar exactely at the price tradet at that time? not a vertica line.
[2015-09-04 18:55:22] |
Yes this is possible and we wrote new documentation here for how to do this with the Time Line study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181 After going to that page, reload it to see the new documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
