Date/Time: Sun, 05 May 2024 06:04:38 +0000
Volume Scan Formula/Crossing of Moving Average
View Count: 1204
[2015-09-03 12:20:57] |
User22591 - Posts: 133 |
Is your software capable of identifying Ultra High Volume relative to volume behind it over any period of time. I am not interested in average volume but the identification of the highest volume bar relative to the bars behind. The crossing of EMA's If you should have any formulas can we have it? Yours Date Time Of Last Edit: 2015-09-03 18:00:07
[2015-09-03 17:59:37] |
If you can write a formula for this, then yes this is possible. We do not provide formula programming help. We can only refer you to this page here: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
