Date/Time: Mon, 29 Apr 2024 06:25:21 +0000
SC 1289 - Tabs Oversized
View Count: 785
[2015-08-31 18:04:14] |
user58907 - Posts: 83 |
Chartbook tabs at the top of the screen have the bottom obscured, Chart tabs at the bottom have tops obscured. Font size seems to be larger. Running Win 7 Pro. |
[2015-08-31 18:11:30] |
You need to change the font size for the tabs in Global Settings >> Graphics Settings >> Fonts.
