Date/Time: Mon, 06 May 2024 08:49:40 +0000
[Locked] - Weekly and monthly TPO charts
View Count: 1062
[2015-08-31 15:13:20] |
calitrader - Posts: 28 |
I use DTNiq as a data provider and I can't get more that 3 profile to load on monthly and weekly charts. I seemed to get more data when I was using CQG broker data. Is there a setting I need to change either in the Chart Settings or the tpo indicator settings? Thank you. Chris |
[2015-08-31 18:18:37] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
