Date/Time: Fri, 20 May 2022 16:22:08 +0000
Trades Taken Data from separate computers
View Count: 1322
[2013-06-13 16:01:30] |
Gary Lockwood - Posts: 13 |
I'm sorry if this has already been posted. I'm trading from two different computers, but I only get the trades taken and summary data on one of them and only for the trades taken on THAT computer. Is there a way to get ALL my trades taken data from both computers, but access it from each? Thanks for looking at this, Gary |
[2013-06-13 22:28:57] |
So is this with Live trading? From both copies of Sierra Chart, are you using the very same trade account? If the answer is yes to both of these, then each copy of Sierra Chart will receive trade data from the backend server no matter which copy the trade was made from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-13 22:53:20] |
The answer is yes to both and I can't see any data on my home computer which I used to with trade live last week (on trial, I recently upgraded to full version, however I had the same issue with the trial version). Also, on my work computer it only shows the trades that I took from it, not the ones I took from home. All of the trades were taken from the same live account. Any ideas? Thanks. |
[2013-06-13 23:04:41] |
To ensure you don't miss any trade data, you need to be sure that both copies of Sierra Chart are actually connected to your trade account at the time of the trade, or at least make sure they are connected before the end of the day. Otherwise you are going to miss data.
[2013-06-14 00:11:23] |
Well that's just not possible. Is there anyway to transfer the data?
[2013-06-14 01:15:21] |
This is a question which involves external systems which are completely outside the scope of our control. We cannot help with it.
