Date/Time: Mon, 29 Apr 2024 06:14:04 +0000
I want to hide the chart values window
View Count: 1684
[2015-08-31 13:00:28] |
DarthSidious - Posts: 63 |
Using v. 1282 nonCLR I want to hide the box that pops up in the left corner of the chart with chart. This one: http://imgur.com/rxNujS4 In chart setting > advanced setting > Display main price graph values in values window: if I uncheck that, I still get a smaller box. Can this be at the top just under the menu items like it used to be? Along with these values that are popping up on a chart? I liked the green connection info that used to be at the top right corner, and looks like the only way to get it back is along with Toolbar 1 or whatever. I don't want to see any toolbar. Is it too much to ask for the old setup back? Or can I customize it to look like that? Date Time Of Last Edit: 2015-08-31 13:03:00
[2015-08-31 14:36:18] |
SC Developer - David - Posts: 660 |
Uncheck Window >> Show Compact Tool Values Window.
[2015-08-31 14:39:57] |
Yes! Thanks David. Now only if I can get the connection status thing to show up at the top right without having to load some toolbar. |
[2015-08-31 14:57:03] |
That is not possible. You are referring to the Status Bar and that is permanently removed. Refer to these sections here: http://www.sierrachart.com/index.php?page=doc/doc_StatusBar.html http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar In "Customize Toolbar #" dialog you can move down Status bar to the end of the list and it will be located at the right edge of control bar. Date Time Of Last Edit: 2015-08-31 14:57:22
[2015-08-31 18:22:55] |
It is necessary to see the Status Bar for the connection status. Unless you look at the top title bar which also shows the connection status. Is it too much to ask for the old setup back?
Yes. This is the discussion thread:New Control Bar to replace ToolBar and Status Bar Or can I customize it to look like that?
What we recommend you do is reduce the Font Size of the ToolBar buttons through Global Settings >> Graphics Settings >> Fonts which will make the ToolBar have a smaller height. Maybe that will help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 18:23:57
