Date/Time: Sat, 04 May 2024 02:39:50 +0000
Trading DOM Interactive scale locked issue
View Count: 923
[2015-08-31 04:23:23] |
User742717 Mike - Posts: 86 |
Hi On the Trading DOM when set to "Interactive scale locked", the mouse wheel still scrolls the prices up/down. Thanks Mike. |
[2015-08-31 19:40:17] |
We are checking this. However, what is the purpose of this request? No one else has ever asked us about this, and although technically the behavior is not right, we think that by locking the scale also when using the mouse wheel when Interactive Scale Locked is set, it is going to be a detriment for most users. If you are merely pointing this out because it technically is not correct, we question if we should change it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 19:48:33
[2015-08-31 23:03:01] |
Hi I use the DOM with the charts, and I have scrolled the DOM by accident assuming i'm on a chart a few times, thought I'd let you guys know. If it effects both the DOM & charts then I guess it's not worth changing, but it really shouldn't scroll. Alternatively, I have the DOM on scale locked and range: const autocenter and it doesn't autocenter after it's been scrolled, which is I guess, the really problem for me anyway. Thanks again Mike. |
[2015-09-01 00:37:28] |
OK we understand. Scrolling will be locked when Interactive Scale Locked is enabled.
