Date/Time: Sun, 19 May 2024 00:04:16 +0000
[User Discussion] - Time and sales settings
View Count: 3532
[2015-08-30 10:26:03] |
User58159 - Posts: 62 |
I am not successfull with Time and sales settings the way, that it is NOT always visible. First picture shows my trading platforma with TaS, thich covers my WTR indicator chart. Second and the third picture show, that possible it is. The third picture shows the TaS, I do prefer .. Please, advice. |
20150829_Dotaz_1.0.jpg / V - Attached On 2015-08-30 10:25:42 UTC - Size: 788.86 KB - 1392 views 20150829_Dotaz_1.1.jpg / V - Attached On 2015-08-30 10:25:48 UTC - Size: 272.7 KB - 534 views 20150829_Dotaz_1.2.jpg / V - Attached On 2015-08-30 10:25:54 UTC - Size: 260.39 KB - 1138 views |
[2015-08-30 11:22:11] |
We are not understanding what you are asking about it. We do see a Time and Sales window in the first chart image and it is blank. What Chart Number is that Time and Sales window for? Do you have an idea why it is blank? And when posting an image of a chart, only use the method described here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image From our perspective, you are providing us with excessive information by these three images. Just provide one chart image only use the method we have linked to. You can provide a chart image with the Time and Sales window overlaid on it by using Edit >> Screen Images >> Upload Chart with Overlays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 08:29:00
[2015-08-31 07:18:53] |
OK, I understand what you mean. Please note, why I have sent my three images, but the first, I answer your question: - the TaS window is connected to Chart No:9 - the TaS window is blank, because of weekend So, the problem I have with TaS window, not with the data .. I kindly ask you to anadvice .. |
[2015-08-31 07:25:15] |
I want to have TaS window on the same place (between chart No.9 and No.10), but I want to see complete Wems´Tape Reader Chart (the Chart on the bottom) ..
[2015-08-31 08:31:32] |
We cannot help with this. Wems´Tape Reader Chart
This is not something from Sierra Chart. Are you aware of this? If so, we should not be asked these kinds of questions because we cannot help with them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-31 08:32:27
[2015-08-31 09:23:19] |
So, I try to explain the same the different way .. 1) To my chart No.9 I have opened TaS window. 2) This TaS window overlay the Char No.3 I want to have TaS window "not always visible ", I want to see full Char No.3. PS: With reference to your unswers I am not realy sure, what is gong on .. |
20150831_Dotaz_1.1.jpg / V - Attached On 2015-08-31 09:23:13 UTC - Size: 796.97 KB - 474 views |
[2015-08-31 09:29:47] |
OK we think we understand now. Therefore, you just need to reduce the height of the Time and Sales window. It is always going to lay on top of other charts. There is no way to change this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-31 09:41:35] |
I thank you. Nice day.
[2015-08-31 10:12:48] |
Sorry for my inconvenience, but if you check the picture above (20150829_Dotaz_1.2.jpg) and compare with my enclosure, there (must?) be the way .. I kindly appreciate you check your last reply .. |
20150831_Dotaz_1.2.jpg / V - Attached On 2015-08-31 10:12:13 UTC - Size: 805.19 KB - 728 views |
[2015-08-31 10:30:05] |
This is the fact, what I mean (please see enclosure)..
20150831_Dotaz_1.3.jpg / V - Attached On 2015-08-31 10:29:53 UTC - Size: 787.15 KB - 468 views 20150831_Dotaz_1.4.jpg / V - Attached On 2015-08-31 10:30:01 UTC - Size: 241.79 KB - 420 views |
[2015-08-31 11:11:52] |
Yes the edges are different and that is controlled by the operating system not Sierra Chart.
