Date/Time: Sat, 18 May 2024 18:46:53 +0000
DOM-waiting orders
View Count: 899
[2015-08-29 18:19:49] |
User627094 - Posts: 1 |
Dear sir/madam, I would like to ask you about displaying waiting orders in integrate DOM (please see attached file). I tried set it up in Customize chartDOM colums, but no success. Would it be possible to help me with this? Thank you very much. Best regards David Munzar |
DOM-custumize chartDOM columns.PNG / V - Attached On 2015-08-29 18:18:09 UTC - Size: 51.42 KB - 273 views Attachment Deleted. |
[2015-08-31 09:04:28] |
You are not going to see market depth data over the weekend because the markets are closed. Since you are using chart data from a remote instance you also need to enable this option: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#NonChartDataRemoteInstances The Chart DOM column settings are currently correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
