Date/Time: Sat, 18 May 2024 23:12:14 +0000
SC - Command line install option
View Count: 974
[2015-08-29 17:19:50] |
ejtrader - Posts: 688 |
SC Team - Is there any command line install option available for this? Have around 6-7 instances of SC platform and would be convenient if I can get this installed using command line any time version upgrade is needed, can simply execute the batch file. Probably a command line something like this? SierraChartSetup.exe c:\SierraChart /NoMSRD /d (no microsoft redistributable package / all defaults) thanks |
[2015-08-30 06:21:09] |
We are developing a new custom installer. We will be sure to add support for this with that installer.
[2015-08-30 13:35:39] |
Thanks SC Team. Typically - there are 3 variables that would be different for each of the installs. Parameter 1 - directory where is needs to be installed Parameter 2 - not to select MS redistributable package if there was ever an SC installed system would have microsoft redistributable package installed already and doesn't need to be installed ( unless the redistributable package version changes ). screencast.com/t/5Zor3gQZ - this is one parameter to deselect MS redistributable package parameter 3 (optional) - Start menu folder name screencast.com/t/rPmzlRMk - This one is another parameter Choose Start Menu Folder Thanks Date Time Of Last Edit: 2015-08-30 13:37:33
