Date/Time: Mon, 29 Apr 2024 02:43:10 +0000
ACSIL - Price display format for Bonds
View Count: 930
[2015-08-29 00:24:09] |
ejtrader - Posts: 688 |
SC Team - Would like to display price value on chart using s_UseTool. in case of general instrument - we can use sc.BaseGraphValueFormat format. Basic issue - this doesn't seem to work well for Bonds - This is returning 132 for number of decimals for Bonds. Is this by design? Ended up making own function to return the correct number of decimals when sc.TickSize is passed. On a side note - What is the equivalent for Bonds - for example - ZF - 119 31.75/32 or 119'31.75 Thanks Date Time Of Last Edit: 2015-08-29 04:58:41
[2015-08-31 19:35:36] |
132 is correct. That is the value format code. 132 is also used for quarters of 1/32. Sierra Chart will automatically detect a quarter of 1/32 and display the proper value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
